Re: 1979 15 Evinrude loss of power, rough idle
I do think that would be the logical choice, but I am NOT a real mechanic and don't really know squat compared to many here. Your observation on the spark plug in the top cylinder doesn't match what I envision is happening with your motor. I hope Tashasdaddy or F-R or some of the other real experts here will check in on your thread before you give up and get the powerpack. I think you also might try spraying some fuel mix from a spray bottle into your carb. throat while the motor is running at a decent speed with someone else driving, or as fast as you can safely do it in a barrel and see what the effect is, to try to rule out a carb. problem. If giving fuel to the carb. gives you a big power boost, it may be a carb. problem.
I like helping folks out when I can, and I do work on quite a few motors for myself and friends, but I'm no professional by far. That said, I think there's a good CHANCE it's the powerpack. I also think that you are being wise to get a spark tester that you can change the gap on. If you have weak spark on one plug, and switching coils doesn't change anything, from my meager experience it is the powerpack. I don't know what else it could be.
good luck----I'll be very interested to hear the results!
JBJ
