Hello, i have a 93 Mercruiser 3.0L with Alpha One outdrive which has tough shifting out of foward gear into neutral when in water, reverse is fine. When running on muffs shifting out of gear from either forward/reverse is fine. I also hear a "clunk" noise when shifting into gear both on driveway and in water, but i was told by a mechanic that this was normal for these outdrives.
I do not have to force the control lever very hard when i shift out of gear, but i do have to apply some pressure that does not seem normal. This is my first boat and I'm new to boating in general and just wanted to get an opinion on what may be causing the problem...
Thank you,
Greg
Thank you,
Greg
