Re: Gear lube leak
FYI, I had to change my impeller this year (had someone show me how), after doing that, I found that the lower shift cable was triggering my interrupt switch and had to have the boat serviced to have it changed. While in the service bay the mechanic found that the lower unit was leaking gear lube at first I thought we must have done something wrong when we changed the impeller but he found that it had ingested some fishing line which had shreaded the shaft seals causeing it to leak. Just thought I would throw it out there.
