Thirsty Turtle
- May 27, 2009
- 13
Well here is my story I have not been able to get this motor to come to WOT since I bought this boat a month ago. So far I have rebuilt the carbs, replaced fuel pump, fuel lines, fuel tank, primer bulb, spark plugs, and powerpack. Compression has been checked three times and is 150 lbs on all three cylinders. Spark has been checked and is good. The motor starts and idles fine. When in the water I can run the high speed idle up and it will open up and run fine. As soon as I put it in gear and try to accelerate it will start bogging down, it will not quit but if you back off the throttle it will smooth out. It is on a 14ft flats boat that may weigh 1500 lbs and has a 17 pitch 3 blade alum. prop. I am not sure if the prop is my problem or if the timing or link and sync. I am not sure how to check this and does this sound like this might be the problem or something else. Pleas help as I am ready to light a match to this thing and I don't feel like waiting two weeks to have it looked at by a shop.
