I have a 2003 Monterey Montura LS 190 Bowrider with a Volvo Penta 4.3 L GL-A engine, sterndrive SX-M.
I am running Castrol GTX 20W50 (which is actually one of the options in the operator manual for temperatures over 32F - I am actually in the Orlando area, which is pretty hot.) I am running with a Fram Oil filter that has been correctly cross referenced. On my previous oil change, I ran with the correct Volvo part number and the results were the same as what I am posting now.
I am getting really low oil pressure readings - sometimes less than 10 PSI at idle when the engine has warmed. I also am getting around 30 psi even at rpms over 3000, let's say 4000 - 4400.
I saw a post for a Volvo 5.7L GSI that recommended the owner remove the oil sensor and attach a mechanical gauge.
Can someone please give me fairly detailed instructions on how to do this with my 4.3L? I would need to know where it is located, when and how to remove it, what kind of mechanical pressure gauge to buy, etc. I have the engine workshop manual and it does not mention the sensor.
