Re: pros VS cons of composite propeller
I have to disagree. I have a 4 blade comp prop on my 3.0LX. Hole shot is so much quicker and top end even went up a couple of mph's.
What did you compare it to?
Comprops were an inexpensive alternative when introduced, but there are no longer cheaper than some of the aluminum props. We have had two very different experiences with them. My father has been running one, on a pontoon boat with merc75, for 8 seasons with great results. When I needed a new prop this was the first on I purchased. Compared to "factory" merc 3 blade, it was an improvement. Lower planing speed, faster hole shot, better low speed control.
BUT
When all 4 blades seperated from the hub while pulling a tuber, the decision to never run composite again was a no brainer.
I replaced it with a Turning Point Hustler, and never looked back. Even though the hustler was only a 3 blade, it is vented and the hole shot about the same as the composite 4 blade, and top speed was considerably higher at the same RPM (+/- 50).
I paid $86 for the composite, $113 for the Hustler and another iboats user just purchased one from this site for $92 shipped. The math just doesn't add up, skip the plastic.
