Recently bought this boat, seller said it had been sitting for 2 years. I drained the gas in tank and put in fresh gas. First time out was only running on three cylinders....turned out to be a bad coil. I put new NGK plugs in and it ran great at WOT, trolled for a very short time then fouled two plugs on left side, cleaned plugs but didn't do any good. Compression is 125-130 on all cylinders. I read that only Champion plugs should be used, are they a better plug for this motor? Also was told to only run premium/non-oxygenated fuel to help performance and prevent plug fouling. thanks
