Re: need identification for johnson
The motor was designed to run with gas that had up to 10% alcohol, but the hoses should be upgraded to this year's type.
The alcohol tends to break down old gas and iol gel that accumulated before ethanol and clog the engine. The alcohol also breaks down after a time allows water to settle into the tank where it can be picked up first when you start the motor.
The best plan is to use a fuel stabilizer like StaBil when you first buy fuel and to add a water-separating fuel filter in the line before anything else. Water separating filters work on gravity and need to be in a fixed position and as stable as possible.
The TC-W3 stands for Two Cycle Water Cooled and at this time of year it should be available at most larger automotive stores, Walmart carries it under several labels including there own.
The best oils for two strokes now are probably the TC-W3 rated synthetics and synthetic blends which generally have a higher flashpoint and burn cleaner. Some, like BRP/Evinrude XD-50 have Carbon treatment built in which is a big advantage.
