Re: no spark
You may have found out it's the module, but WHY did a new module go out after five minutes.
Is it hooked up to your ESA system? Is it compatable with the ESA? That is why I asked if you shifted it, did it die when shifting.
You may have bought a kit, but were they aware it went in an OMC?
You better figure out why that module went bad, or you will be spending a lot on them. Call M Motorz and see if they will warrant the failed module.
