kevinclark93
- May 11, 2009
- 42
I have a 1996 Merc 150 offshore. As soon as I turn the key on a constant beep alarm goes off.
I am in the process of trouble shooting the sensor. I have found two sensors one on each side of the engine, and I am not sure what each one is. The one on the right side has a Tan/Blue wire with a seal, spring and then sensor. The other on the left side of the engine has a Solid Tan wire going into the sensor and the sensor is one solid cylinder.
I have read in other post that you need to unplug the temp sensor to see if the beeping stops. On both of the sensors I have found the wires do not disconnect, they are either soildered or bonded, so how do you recommend disconnecting them? Also which one is the temp sensor.
