Re: Mercruiser Fuel Pump
I have the fuel pump without the return line. Someone told me that when the diaphragm bursts the pump will lose it's pressure causing the motor to die thus fuel would not leak into the hull. Let me know your opinion
the short of it is. if your gonna replace it. replace it with a new style marine fuel pump. similar to this...
http://www.ebasicpower.com/pc/MAL9-35419/ALL4C/Fuel+Pump,+Inline+4,+6,+Mercruiser+3.7L,+60032
if the diaphram ruptures on your present set up. it will leak into the boat. one way or the other. fuel fumes... kaboom if it finds a spark.
if your absolutly set on going with what you have, ya might check out the mercruiser dealer and see if the diaphram is still available. it looks like it might be, item #3...
http://www.mercruiserparts.com/Show...br=983&bnbr=30&bdesc=FUEL+PUMP+AND+CARBURETOR
just keep in mind. if you don't go with the new style marine fuel pump. by todays standards, your taking your life, your familys life, and any one in close proximity to you life in your hands. if you blow, if you live, you'll probably be sued till you've got nothing left. your insurance company probably won't pay either since they'll probably come find this thread and find out you knew the difference from a auto vs marine fuel pump. you've been educated now, so if you decide to replace it. make the right decision and replace it with the newer style marine fuel pump and be upgraded and much safer.. windsors set up looks good to me......
