Re: 8 hp johnson won't stay running
I am having pretty much the exact same problem with my 89 8hp. The major difference being when my dad and I pulled it out of storage and prepped it, it ran great for 20 to 30 minutes. It idled great, throttle response was very good under load, it idled for 5 minutes and when I gave it throttle it picked up very nicely. I towed it 26 miles to my house and now it will run for 10 or so seconds and then die. I replaced the plugs and checked spark. fuel is flowing to the fuel pump very well, new fuel, even a new tank. It will run some what with the starter enrichment knob pulled out, but it will not rev up, and within a few seconds of pushing the knob in itg dies no matter what position the throttle is in. It will not even try to start unless the primer is used, and even then I can not idle it down at all. I am thinking the long storage had caused some build up of junk in the carb and that towing it caused it to block something in the carb.
I am going to pull the carb and see if I can find anything, I will post back when I get it figured out. Till then, I am going to keep an eye out here for a possible solution.
P.S. What is the base setting for the low speed needle?
