Coral Reefer
- Sep 1, 2008
- 9
confused:I have a 1972 Johnson 65 hp Hydro electric shift. How can I tell if the charging system is working correctly? The last time I took it out The battery died and I had to row it back in. I'm hoping it was just a bad battery. Is there a particular voltage to look for and how should I test it? I replaced the rectifier and had no change in readings. The stator is fine I believe as it runs just fine without a battery. When I have the motor running I get 10.7 volts at the battery cables without a battery. Shouldn't this be about 14 volts or so? Also, when I turn on the bilge pump with battery connected the voltmeter goes from 12 to about 10. If I disconnect the cables to the motor, and turn on the bilge the meter goes from 12 to about 11.9 volts.
Thanks, Jeff
Thanks, Jeff
