Re: Core Sample Help Needed
hello hardiek ..
ermm.. if its all fiberglass stringers then why are you asking about cores ???
seeing as core samples are normally for hull or stringers..( which you said are fiberglass..then why ask ??
Thanks for everyone's help. I am very slowly getting better at this boat restoration game."
hmm..what are you wanting to restore ?
180 4W is simple.. your main question should be about outdrives and your motor..they cost more then the boat is worth personally.....
YD.
YD,
Thanks for the reply. Here is the deal.
I bought a 94 four winns horizon 180 with the interior needing replacement. I have never owned a boat before so found this site and asked some questions about how to restore the interior. The first thing that came up was to do some core samples on the stringers and the transom. I did the samples this weekend not knowing that the stringers were fiberglass (I think they are, but I am not 100% sure still). The core samples were dry, but they did not seem like wood (the drill bit went through very way to easily through an 2" stringer and I found no evidence of moisture whatsoever).
So I was asking how to tell the difference between wood and fiberglass stringers to verify they are fiberglass and make sure that I am on the right track.
If anyone can tell me how to tell the difference I would appreciate it. FYI, I plan to call Four Winns tomorrow to see what they say.
Thanks to all.
Kevin
