Will furnish pictures later but boat is 15 ft fiberglass. There are 3 stringers, one in center that runs length of boat and two that run from stern forward about 5 feet. These stringers protrude into the hull which leaves a flat inner hull. Stringers and transom appear solid. I plan to encapsulate plywood in fiberglass for the new deck. The new deck will rest on the inner hull. There were some remnants of foam present when I dug out the old rotted core (cedar fence boards laid cross ways the entire length of the boat) but certainly not enough for any flotation benefit. From a flotation standpoint I don't see how it can matter. From a structural standpoint will there be a problem with the deck (fiberglassed plywood) resting directly on the inner hull and fiberglassed to the side? Since I plan to use 2 sheets of 4/8 plywood how would I even get foam in place without drilling holes in the plywood?
I have read the many discussions about epoxy vs polyester resin in fiberglassing the plywood and still have that decision to make. I have found polyester resin locally but not epoxy so far. Would the polyester resin be suitable for attaching (fiberglassing) the new deck to the side (gunnel)?
Thanks for input.
Ron
Thanks for input.
Ron
