Have a OMC 3.8 Chevy motor not sure which outdrive (Ihave been trying to figure that out, any suggestions?) my problem:
I hooked muffs up to motor started and checked all gauges, everything works except water temp, I am not sure where the Sending unit is located it was starting to get dark so I did not look along time. I will tomorrow. I also noticed that the water hoses did not seem to have any pressure on them after I had shut the motor off. I ran it about 3-4 minutes. The other thing is I did not notice it peeing like I think it should. there was water coming out of a hole just below where the muffs hooked up and that was it. I am not sure where all it should be peeing.
This is the first inboard I have owned and it is a project boat, it is a 1985 Galaxie 18' 0" 225HP. I have redone all the interior and wood and I am trying to get it lake ready and double check everything. I have read several post and even tried to follow the link on the service manual but it would not load. Any help please.....
thanks,
Dan
thanks,
Dan
