Johnson 1979 55 hp compression numbers
claimer
Hello I have a 1979 Johnson 55 hp outboard and I am getting 110 lbs on each cylinder. Was wondering if this is enough compression or do I need a overhaul?
Thanks
Robert
Boss Hawg
Re: Johnson 1979 55 hp compression numbers
Thanks
Robert
From what i've learned thats good - Better to have close to the same on each than a bunch here & there ;)
5150abf
Cold or hot?
Mine are 110 cold, 135 hot so you pick up quite a bit having the engine warmed up.
Either way as stated you are fine, I check mine once in a while just to keep tabs on how the engine is doing.
claimer
Thanks for the response. Just wanted to make sure the compression was good before I do some needed work on the engine. The test was done on a cold engine.
Thanks again
Robert
