scrampbell
- Feb 25, 2009
- 108
Hi All,
Motor was running well cruising at about 80% throttle when suddenly it was as if I slowly throttled down to 25%. I took it down to idle and tried to throttle back up just to see what it would do. It didn't do anything and it died seconds later with two squeeks with the last two turns of the motor. An excessive amount of oil showed up in the water and when I tilted it up, oil dripped out of the cowling. It's a pull start and the pull rope won't budge much at all now.
I haven't had a chance to take off the side casing to get a good look at it, but the bulk of the oil seems to be in the forward starboard part of the engine, below the muffler and forward of the carb.
Anybody have a good idea of what this is?
Is a crack in the cylinder likely and would it result in such a quick result? I've had problems with debris in my fuel, but just replaced the fuel filter (it's on the fuel line). Could a big piece of debris break the o-rings (which would explain the fact that I can't pull it at all)? Would a bad line cause anything that even remotely matches this description (it would explain the oil in the engine compartment)? I believe that there are other pieces of the engine that run off the cylinder (the impeller?) so maybe if one of those things was broken it wouldn't allow the engine to turn... does that make sense?
Thanks a ton for your help and time!
