Re: Trim Cylinder Rebuild Help
It is easy if your boat has never been in saltwater, has never been in polluted water, has never been in acidic water, and has always had a good anode. But if you can see any galvanic corrosion (looks like limestone deposits) then the worst place on entire engine is the trim cylinder and lower trim mounting shaft. Galvanic corrosion can turn a one hour easy job into a 16 hour nightmare.
If you have lost or missing centering ring from top of cover then don't bother trying until you have found a replacement.
