I recently purchased a boat w/a 85 hp force. The first thing I did, before buying the boat, was have a mechanic check it out. I know little about boat motors. The mechanic said the engine checked out except slightly low compression in #2 cylinder, but he felt it would be OK and may come up. We have been running decarb treatments. About 13psi difference. 150, 136, 148. The mechanic changed water pump, rebuilt fuel pump, changed all fuel lines, inspected electrical/ignition system, cleaned, boiled carbs,etc. Thourough inspection/service. I did not have a prop so he gave me one he had laying around, he used it as a steering wheel puller and its about 37 years old.
I took the boat out for a test run. The engine starts like a champ and eruuns good except two things occoured that have me concerned.
1. Through the lower range of throttle, all is good, decent power, but when in the higher range, full throttle, I suddenly loose propulsion. It returns again in lower range of throttle. This problem is intermiten, some times I can run at full throttle with no issues. Im getting two replies to this: One, the prop is spun and needs to be replaced; Two that the prop is fine, if it had spun it would not return in the lower range of throttle. Not sure which way to go. What else could it be or is it likely the prop.
2. I seem to be missing a range of throttle. When pushing the control forward, the boat accelerates to a point, and as I continue to push the throttle forward, no change, then all the sudden the bow jumps up and it takes off. On one occasion, I pushed the throttle forward, with no change in accel, took my hand off the control, about 1.5~2 seconds later the engine responded, the bow came up and... My mechanic seems to think it has something to do with the S cam.
Any thoughts greatly appreciated.
