Got me a shiny, new-to-me '57 Fleetwin replete with a shellacked(?) cork float in the carbie.
It'll soon be getting its first dose of heavily subsidized, midwestern methanol spiked, unleaded gasoline.
Should I worry about my cork?
Thanks, that's very helpful.That is ethanol, not methanol.
Thanks. Googled and ordered!The guaranteed, fool-proof, and simplest way to fix the problem is to put a new float in it. The new one is part number 396514 and is made of an alcohol-proof material. The problem will be solved.
Thanks, that's a clever trick, I'll follow it with the float in the gas tank.Alcohol dissolves shellac. Remove the cork float. If it's in good physical condition, let it dry completely, then coat it with cyanoacrylate super glue and let it dry completely. Alcohol doesn't affect that stuff.
