I will start out with last years problem, I had a miss in one cylinder and after swapping coils around and no change in location of the miss i swapped the switch boxes and the miss moved to the other side of the motor, i replaced the switchbox and problem solved and the motor has been running perfect since last summer, until today that is, it all started out fine and all of a sudden lost power and i bareley limped back to the ramp,so the first thing i did was check for spark and 3 cylinders on the same side of the motor are all dead so i figured maybe switchbox went bad, I swapped the switchboxes and the same cylinders are not firing, could this be the stator ?
