I have been trying to debug a '78 Johnson 115 for the past several months and haven't overcome these problems yet. Listed below: (I had previous posts)
1. The main problem is that it has low power (or torque) to get the boat (17 ft. Champion Bass boat) out of the hole. The engine bogs down at about 3500 rpm with full throttle. If I redistribute the load (passengers) to the front it will gradually get out of the hole and plane out, with the engine rpm increasing up to rated speed of about 5500 rpm.
2. When trolling, slightly above idle, after a few minutes, the engine will start smoking, badly and running rough. I have to take it up to a higher speed for a few minutes to blow it out, then I can resume trolling. It is like one of the cylinders may be flooding.
3. The tachometer quit working. Could this be the rectifier?
Here are some of the things I have done.
1. Checked the ignition--per recommended spark check, and per all of the recommended tests in the SELOC manual. I used an ohmmeter for the peak voltage measurement. I also inspected the stator coil.
2. Overhauled the carbs. Checked all the high speed jets.
3. Overhauled fuel pump.
4. Installed all new fuel lines and eliminated air leak from tank.
5. Gave it a Sea Foam treatment. Spraying it in the cylinders, letting it soak, in the intake, and in the fuel.
6. Replaced the spark plugs.
The compression checks out at about 95 to 100 on all cylinders. Could this be the problem? Am I going to have to tear this thing down and overhaul it completely? I have not pulled the heads to inspect the cylinders.
Your help and advise is much appreciated!
GRW5
GRW5
