Before anyone tells me to use the search function, I have been exploring google for months to help me find and answer to this question.
Quite literaly days after purchasing the above mentioned vessle we had water within the oil, noticed after the valve in cyclinder 1 cracked. We dismantled the head and made the neccessary repairs. This included having the head pressure tested (which came back fine), replaced the head gasket. we noticed the 'flap' with the exhaust was missing so replaced this and more recently we replaced the exhaust manifold.
Since all this has been done water is still getting into the oil. Our first thoughts were that the existing condenstation was causing the problem, but the water is incredibly milkly. The oil has been changed several times along with the oil filter.
All we can presume now is there is a crack in the block, but im led to believe these are extremelly durable - is there anyway to test?
What seeems the strangest is that the boat is now running perfectly, when the hose is attached with ears, the oil remains fine. But after a day on the water it isnt anymore. Can there be anything at the transom causing the problem.
Because i have the feeling we are only getting water in the oil when the boat is in the water. Could this be because the engine is getting hot enough for any cracks to expand?
Any usefull information would be appreciated, please dont not waste time posting any critiscm or pointless posts it helps noone. Must of the threads i have read have a question with some suggestions but no final results.
Thanks again in advance.
