Hi there! I'm hoping someone can help me with this. It's a '69 I believe, red stripe. Sometimes it won't even start, but when it does, it will run fine, then bog down and shake and pop, I would describe it as running on one cylinder. Then it will come back to life and run fine. It mostly does it at idle, I don't think it has ever happened up on plane. When it starts to do it at idle, if I give it some gas, it clears up, runs okay, but it kicks so bad, it almost rips the tiller out of my hand. Then sometimes, it doesn't do it at all.
New plugs, new wires, new condensers, new fuel and I have gone through the carb, although I do not suspect a fuel problem. I haven't replaced the coils or points, because they are all about $100 a piece. The points look fine. Is there a way to test the coils? That is about the only thing left that I can think of. I've had this motor apart about 20 times in the past year trying to narrow it down. I know, I should just take it in, but I'm broke, and just want to get out fishing! Thanks in advance. Ole
