gatesmoonwalker
- Sep 18, 2008
- 20
1996 Alpha One Gen 2
Pulled drive before the end of last season for a quick fix and made a note to myself that I need to look at shift shaft bushings as it seemed like a lot of play.
Reading up on outdrive maintenance today and want to make sure I understand this correctly. I read it as in the later models the shift shaft fits loose in the upper and lower bushings. In fact, I think it said very loose.
Am I off base here or is this correct?
This was from the manual in Don S sticky.
Appreciate the expert opinions - Thanks
