Re: Problem with trailer lights
Your lights need to be wired this way, first, the white wire, is battery negative and each light must be connected to the frame of the trailer or to this wire. This is usually a white wire on the light assembly as well.
Green is your right turn and stop lights
Yellow is your left turn and stop lights
Brown is your tail lights and side markers.
The white wire, or ground, needs to be connected to the trailer chassis, the trucks trailer socket should have this pin connected directly to the trucks frame.
If your dealing with a tilt trailer, then the best thing to do is to extend the ground wire from the trailer connector to the rear frame, if you have a trailer in which the frame bolts together, such as a Load Rite, or similar, then run a separate ground to both the left and right frame rails.
Loose or rusty bolts will impede the ground connection.
(Your taillights get their power half from the chassis of the truck and trailer, and the other half from the wiring harness. The white wire simply ensures the trailer is sharing the chassis ground connection with your tow vehicle.
