I was bench running my rebuilt merc 260 today to run in the new cam.
As part of the rebuild I installed a new Delco EST distibutor.
After the engine was good and warm...140? per the temp gauge I attempted to set the timing. Did this per EST procedures...while engine is running connect timing shunt and +12V...
After setting base timing @ 10? and removing shunt I rechecked timing and noticed it did not advance. So I throttled it up and it actually retarded.
Is this a problem with the distributor module or am I missing something?
By the way , the engine fired right up, no issues starting whatsoever.
Thanks,
Thanks,
