Re: Is this johnson kicker good enough
A 2hp would push it...but not well. You'll have to go WOT and it'll probably rattle the crap out of you. I use a 4 hp yamaha 4-stroke kicker (less than 50 lbs) for trolling for my 14 lund which does a great job...but the boat weighs in just over 500 lbs. I have also used my 2 hp also on a 21 sailboat (1200 lbs) on lakes without any problems if there was not any strong head winds or currents. When I raced my sailboat, I wanted the lightest motor possible to cut down on weight...and the 2hp was the ticket!
It depends on the weight and hull design of your boat and how far you venture away...but I would not suggest a 2 hp as a reliable auxillary. A 5 hp maybe...depends on the boat!
MAS
