reelfishin
- Mar 19, 2007
- 3,043
I had to go pick up a boat and trailer I bought yesterday, it was a 330 mile ride one way back with a trailer with 8" tires. I took four new tires and rims with me, two sets of spare bearings and hubs, and several loaded grease guns.
The trip went well but I had one odd issue with one wheel. About half way home the left wheel started to sling grease, all over everything. I gave a few shots every so often and all went well.
When I got home, I found the cause, a piece of old string had gotten wrapped around the axle and into the seal, this allowed the bearing buddy to push out the grease in volume. The result was not what I had expected, the tire was chopped severely from the ride, it looked like someone cut chunks out of the tread. What had happened was that the grease stuck to one side of the inside of the rim, thus putting that wheel severely out of balance, this scalloped the tire badly. It made it home, and I replaced the tire and bearing kit. I made it all the way back on the original tires and bearings. All I did was to adjust and lube the bearings before leaving. I kept the speed down, and made it home.
Its a light boat, so the trailer had it easy but I'm never comfortable on the highway with 8" wheels.
