Re: Tandem Axle Trailer Tire Scuffing
Again hate to burst ur bubble most ramps are only 7-12degrees. They always seem way steeper than they actually are.
I get your point but hear me out.
Mind you, these are not your typical ramps. We can get up to 3' of tide elevation and the places that have very limited space can only accommodate the changes in water by having very step ramps. They are little more than concrete dumped down the side of a slope to accommodate backing a trailer over the edge. Even at low tide you might have 6? of ramp exposed.
We also have several what I could call floating ramps. They are constructed of what looks to be heavy gauge tubing. Look similar to a metal farm gate. You back the trailer on to them and they sink allowing for you to launch and retrieve a boat. Again, not intended for anything other than the back end of the trailer.
Ok, calculated the angle using length of my boat and the depth of the water when loading on the trailer. I come up with a minimum of 21 degrees. I say a minimum because I'm calculating the angle using the depth at the back of the boat and I don?t know how deep the water is forward of this position.
