Hello again,
After reading what others said about my super glued oil line I decided to fix it right. So here is what I discovered, I thought the leak was coming from the line on the cowling side of the filter, but after closer examination I found there to be oil on the line by the pump itself. I figured it wasn?t supposed to be there so I took the clamp off the line by the pump and left it alone. I'm not sure how long it will be until I get a new line so I didn't want to remove it from the pump until I'm ready to put the new one in. So on to my questions, I figured since the line is getting replaced, my best bet is to cut the old one off from the nipple on the pump; does anyone have any suggestions to make this easier? I'm not going to be able to start the motor until winter is over so I really will have no idea if I did everything right, but I don't think this is a very hard job, it's just very tight because the lower cowling isn?t off. Then I think all I have left to do is purge the air from the line. One more question, if there?s not supposed to be air in the oil or gas line, then when you replace the fuel filter wont that let air in? Any advice is GREATLY appreciated. (1992 60hp VJ60TLENE)
