Hey all, been working on a '84 115 inline for a while now, It was dry for quiet some time prior to me working with it. Anyway always seemed to crank right over without a problem, but the water pump was bad so i never really ran it. So I replaced the wp last week change the fluid and had also replaced a bad stator sometime ago. Got it all back together fired it up all worked great, on muffs though it took some time to crank over, gave the battery quiet a workout, and at one point the starter actually stuck in on spinning though not engaged until I tapped it and which time it quit, (funny thing I had turned the key off) Now again it eventually started and ran great every thing worked without problems. Fast forwards about a week, I've got a can to dunk the thing in, filled it dunk the motor fire it over and nothing but a dull hummmm. try,try,try,try all the same. open housing up found the starter engaged in the flywheel and stuck would not retract when key was turned off. and would not turn the motor when the keys was turned on. I manually tapped the top of the starter and it retracted. I can turn the motor by hand (though not easy mind you, lots of compression) Now when I turn the key on the started spins but does not move up and engage the flywheel it just spins in place. , Measured the volts at the large yellow wire going in ( i assume is the hot) it shows just under 2 volts when the keys is turned. So I'm lost as to the real problem.
I'm I looking at a starter problem?
or
I'm I looking at a selinod problem where the hot from battery, switchs over to the hot for the starter with the key? (the connection right under the starter in the lower housing)
or
Is this some else and I'm way off base?
Sorry for being so long winded, figured details were required at this point though.
or
or
