Jeepster04
- Jan 5, 2009
- 481
New member here. Been reading for awhile though, tons of info around here!
We purchased a boat with dual Volvo Penta 5.0's and Volvo DuoProp out drives this past spring. Both engines ran great all summer, started right up and ran fine. Since we were new to this type of boat, I think we were a little ignorant about maintenance and took the previous owners word saying it just had a 'tune-up' for granted. We have no idea what they includes and he didnt either.
The problem were having is when idling around pulling out of the dock, shifting into or out of forward or Reverse gears out on the lake, and of course idling back into the dock, etc. The engines will stall when shifting into gear, after youve already shifted, its really kinda random but boy does it scare the crap out of you when youre backing a 78ft boat out of dock towards other boats and BOTH engines die at the exact same time. They seem to run fine when you throttle them up. I did notice that the port engine was running around 400rpms lower than the starboard engine at WOT. The Starboard was running around 4,400 while the port was running around 4,000rpms. Im not sure if both engines are dying at the same time or if one dies and we dont notice it then the other dies. Im sure some of you have noticed sometimes when a engine dies the tach will stick at that rpms till you start it back up.
The season kinda ran out on us before we really started to study on these engines and what needed to be done. We were able to change out the spark plugs which were in decent shape besides being a little fouled(wish I had pics). We changed out the Water/Fuel separator on the starboard engine and it was full or junk/rust. The starboard engine had a fuel pump go bad which is why I change the filter, weve not changed the filter on the port engine yet but we will come spring. We were thinking of getting the carbs cleaned and adjusted in the spring but were not sure if thats the problem($$).
So far weve got new distributor caps, rotary buttons, already put new plugs in it, and were going to replace the impellers just b/c. Also going to change the oil since it needs to be done.
Any advice is welcomed!
Number from port engine:
4100113751
4100113751
