Dirty Dawg
- Sep 7, 2008
- 172
Happy New Year all!!! Need some help/suggestions.
We had some rain then cold temps and some snow up here in Long Island NY. My first boat, a ft Sea Ray bow rider has a semi custom cover on it and no matter how much I tighten it and how many poles I set up inside to increase the slope of the cover I am getting pools of water and ice that form in pockets. Also when it snows, the angle of the cover is not steep enough so the snow just sits there. It slowly melts penetrating the cover and increasing the moisture inside the boat and will probably tear the cover if the weight gets too much.
My thought is to put a second plastic tarp over the boat with high angles to let the snow slide off. I was thinking of a simple "U" frame made of PVC piping running down the middle of the boat with the tarp over it to form a tent type of shape. Perhaps some cinder blocks to weight the uprights (I have a few laying around) and maybe 2 in. PVC. The distance to span would be 25 ft. long 9 ft width and 8 ft tall.
So what does everyone think? Is 2in PVC strong enough? Will the wind simply knock it over? Should I leave the ends open or closed up? It would either allow for air to circulate but may let the wind in knocking it over?
Any others, SIMPLE suggestions? ( Do not have a GARAGE to putthe boat in!!!!)
Thanks Ike
Thanks Ike
