Re: My tri-hull transom replacement w/ pics
Hey Drewp,
Got a question that I think you've already answered, but I can't find it so I'll ask anyway.
How much of each kind of glass (tape, csm, woven, etc.) did you order? Or should I say, How much glass will you end up needing by the time it's all said and done.
The reason I ask is cause I'm trying to budget for how much I'll need, and since we have similar boats I'll use your counts to guesstimate how much I'll need.
-TLove
Lemmi see- I started with 10 yards 38" 1.5oz. CSM and 10 yards of 38" 18 oz woven roving. I also bought 5 gallons of laminating resin. I have since bought 10 more gallons of resin, 20 yards of 1.5oz. CSM and 20 yards of 16oz. Woven Roving in 50" width. I also bought a roll of 12" 1.5 oz CSM tape. My guess at this point is that I have plenty of fiberglass. I may run a little short of resin. (maybe 2 additional gallons to finish)
I bought the fiberglass anticipating that I would have some left over for another project. The amounts I bought were based on the cost effectiveness of buying quantity over specific cuts of running length.
The best advice I can offer is this- If you are doing transom, stringers and deck start by buying 20 yards of 1.5 CSM and 10 yards of 16 oz. Woven Roving. Buy 10 gallons of laminating resin without wax. That should be a good start. You will likely need more resin down the road. Also get 1/4" chopped fibers, Cabosil and a pint of finishing wax. You will need the fillers for fillets in tight corners. A roll of CSM tape (12") is great to have for stringers and for edges of decks as well as tabbing stringers and around the transom. It saves a ton of time not having to cut all those narrow lengths. BTW- I started with 18 oz Woven Roving, the 16 oz. works much better in tight turns layed over wet CSM.
I wish I could be more specific but here is a synopsis,
15 gallons laminating resin (polyester)
20-30 yards 1.5 CSM (38" and 50" widths)
10- 15 Yards 16 oz. Woven Roving (38" and 50" widths) forget 18 oz
1/2 gallon container of Cabosil (aerosil, fumed silica its all the same)
1/2 gallon container of talc powder (saves on cabosil for thickening and its cheaper)
2-3 qt container of 1/4" chopped fibers (for strengthening fillets)
