omc 2.5 battery hooked backwards!!
Status
Not open for further replies.
bamadave
Re: omc 2.5 battery hooked backwards!!
Bayliner, It's preferred that you start your own thread instead of hijacking. It can get very confusing when there is more than the one thread. You'll also get far more help that way. Good Luck!
did u get ur boat going i did the same thing and had to change all fuses and starter selanoid i still have no power to dash try to find trim and run down a 50 amp fuse there
there are two 50 amp fuses in black rubber boots with red wires going to them check them i did the same thing and that what happen to mine i got mine fix to day thought that i share almost look like there are part of steering pull them apart fuses in them let me know thanks dust
Status
