txmntman
- Dec 5, 2007
- 108
ok, guys, I need some ideas. I have a 1975, 15ft Sea Squirt. It seems to be in pretty good shape, especially for the year. The bottom has no visible holes or cracks. The boat is quick out of the hole (with only a 40HP evinrude) and has a top speed of 31 MPH, so the boat is not heavy (I'm believing no saturated foam). The transom seems solid. All looks pretty good with the boat.
The problem. When I take the boat out, it will take on water. I'll estimate about 2-3 gallons per hour, and I can tell this by the amount of water which drains from the bilge upon pulling the boat out of the water at the boat dock. I don't think that amount of water can come back through the bilge plug (the screw in type), yet I don't have another source. This is a fiberglass boat. I don't see an easy way to access between the deck and the outside hull. If this were an aluminum boat, I could find it easily. Any ideas on this fiberglass hull? Any ideas would help...
