Ok, getting back into boating after a long long time.....
1978 Galaxie XL2200, 21' 6" length.
350 Chevy crate motor with 100 hours on it.
Mercruiser outdrive w 23 degree 5 blade stainless prop
Above is how the boat came
Boat is in Reno, NV running at 3800 feet altitude at Pyramid Lake
Took it to lake to run the first time. Boat will not exceed 3000 rpm, if the speedo is correct going around 35mph-37 mph, ran with trim all the way down, water temp was running around 180F......when i slow down to let it cool down, it actually heats up? Is this normal?
Thinking I probably need to do the impeller, and oil in the stern drive at the same time, correct?
Second time to the lake, put 17degree 3 blade prop on, and now with trim slightly up, boat will pull 4000-4100 rpm around 35mph, but strangely, I noticed when putting the trim down upon putting the boat in the water, the down button was very hot to the touch????? After running for about an hour, smoke was coming from under my right leg, didn't seem like exhaust smoke, more electrical........when I slowed down, the smoke went away, when I sped up, the smoke came back.....help?
Various people in the know, told me that I should be running in the 4200-4600 rpm range, is that correct??? Seems like this boat should do around 45 to 50 mph
Also, when I get the boat on the trailer, I have exhaust stains around the lower back half of the boat??? Some people say it is running rich, but I am wondering if there is something wrong with the exhaust bellows????
Speaking of rich, the plugs that I pulled look like they are brand new, definitely not a cocoa color.......is it acutally running lean???? It has a quadrajet carb on it.....should I play with the jetting??
Also, when I pull the drain plug on the hull, about two gallons of water come out, doesn't seem like leak in cooling system, maybe coming in through the outdrive somewhere?
Any help will be greatly appreciated!!!!
