les morgan
- May 11, 2007
- 49
I have a 1983 merc 50hp 4cyl motor and the upper 2 cylinders are not getting
fuel. It happened before and I could remove and clean the carb, then the
problem would go away for a few days. Now I have rebuilt the upper carb
again and tried a different carb from a spare engine and still have the same
problem. The main problem is that the upper carb does not seem to have
any vaccum to pull the fuel into the cyls. I can hold a clean rag over the
lower carb and the engine stumbles and dies, but when I do this to the
upper carb nothing happens---- also adjusting the upper idle control screw
it seems to make no difference. Does anyone have any suggestions before
I have to pull the powerhead to check the reeds?
Thanks
Oneoarinthewater
Thanks
Oneoarinthewater
