Hi,
This problem started intermittently. The Engine would rev up for about 1 second and then cut out for about 1 second. Then it would just heal itself.
I would take it home and could not reproduce the problem
On my third trip out, it was running fine until I hit a wake and pounded the boat (this might be unrelated) but then it started cutting out hard. I made it to port and took it home. I was happy to find that it was still exhibiting the problem.
I suspected the carbs so I popped a timing light on it (strobe is a great way to view fuel atomizing into the carbs) and much to my surprise I observed the strobe cutting in and out with the engine, so it looks like the spark was cutting in and out.
Because of the wave action, I suspected a loose electrical connection. Again, this might have been a coincidence but...
1. I disconnected the black/yellow cut out switch connector about the rectifier, no joy
2. I checked all the wiring for the timer/sensor but didn't see any loose wires or connectors.
Now I suspect that it might not be a loose wire at all but the power pack. My guess is that the electronics overheat in about a second and the power pack cuts out. After cutting out for a second, the semiconductors recover and spark comes in again and the oscillation continues.
Thoughts? Has anyone seen a power pack exhibit this behavior?
Thanks in advance!
Thanks in advance!
