Re: suzuki DT 50/55/60??? Can anybody i/d this?
Thanks JamesR for the help.
I haven't been able to find ANY 2 cyl DT55s on any sites or in any manuals. All I can find in that sort of HP range are the DT50/DT60/DT65 2cyl models. BUT, as you have said, the serial number is 05502.
Doesthis mean that the engine's definitely rated as 55HP? If so, then it's a 55HP 2 cyl, which as far as I can tell, doesn't exist!!
The reason I'm worried about this is that I can't get any UK engineers to do any servicing, and I can't get parts to service the lump myself.
I don't really want to find out what if anything's wrong in the middle of the English Channel. The engine starts OK, but I've only run it on water muffs so idle etc is a bit difficult to judge.
My plan was to take the two carbs off, blow through the main jets, idle airways etc, replace the points & maybe replace the water pump impeller(although I hear that's a pig of a job???).
Once I've got a reasonable idea that the basics are OK, I want to take it for a run out at sea.
So - I'm still not 100% sure what this 2 cylinder, 05502 engine is. It says "55HP" on the cover but it might be a replacement cover from another engine. It's white, with a white leg (it looks original - scratches doen't show any other colour underneath). Is it really a DT 50 or 60? Or does anyone know of a DT 55 2 cylinder Suzuki?
Cheers
Andrew
