Hello all,
Went out on the lake last week with my '97 Volvo SX for 4-5 hours and did some cruising and sking, at the end of the day I had an overheat problem.
Ran for a couple minutes of WOT. When I came down to slow throttle I noticed the temperate guage rising to around 210. I shut then engine down and let it cool for alittle while then turned back on. Was at around 175 then climbed back to 210 or so pretty quick so I shut it down and got towed back.
First thing I did when got back home was take impeller out of sea water pump. All of the fins looked good and rubber seemed like it was still in good shape. When I spun the pulley the impeller would not spin, but the pulley and shaft spun very easily.
The impeller seperated from the brass plug it is molded to. Is this a common occurance? There was very fine rubber dust around the brass shaft, I'm guessing from the impeller where it was molded to the brass plug. Any reason the impeller would fail like this? Thanks,
-Aaron
-Aaron
