I have a 1995 Suzuki DT25, 3 clyender 3 carburator 25 hp 2 stroke motor. It has an electronic throttle valve sensor which needs to be reset often. Once the throttle valve sensor is set it runs fine then after a while the motor starts slowing down and the throttle valve sensor needs to be reset. Does anyone know why this is happening. The mechanic at the local Suzuki dealer says that should not be happening and told me to check my fuel. I have new tank and new fuel same problem.
Help??
Help??
