mattandmelissa
- Dec 18, 2007
- 24
I have got a 1993 kingfisher bass boat that is 20' with a 1991 175 evinrude loop charged. I can't seem to get the speed I think it should have I am running at 6000' running a 20 pitch raker I can get 40mph. I have a detwiler 8" jackplate If I raise the motor I loose speed the boat seems like the bow is to far down in the water like I need to have more bow lift. Engine rpm's are 5000rpm with the raker I have tried a 23 pitch renegade and a 21 pitch sst they all do the same thing my motor when it is down all the way prop shaft is around 5 inches below the boat. Is it possible that the motor needs to be lower. Or do I need a better prop my raker has been repaired by propco the renegade is new the sst I have no idea. I tried a 23 pitch tropy and could not plane it would rev to 5000 stand on its tail and never plane sent it off to be rehubbed and same thing. I am at a lose but I know if I could get the bow up It would be way faster it is cutting the water way forward on the bow. Anyone got any Ideas?? The motor is in good shape I have tried two different motors of the same kind and both are almost Identical in performance.
