SeaRay Weekender
- Apr 25, 2008
- 18
Hi folks, I have a 1986 Sea Ray with a 5.0 liter 230 HP Mercruiser/Alpha 1/ raw water cooled. It has the 1st design type thermostat housing- 1 hose to each exhaust manifold, and one to each riser. If I were to remove the hoses from the thermostat housing, open the drains and put a garden hose into each hose to flush out the manifolds and risers- is there a chance the water would run back into the cylinders through an open exhaust valve? I would like to flush out these components as well as the block and hose to the gimbal housing as I suspect there may be some sand in there somewhere blocking coolant flow due to being grounded on a sandbar with the tide going out recently. I replaced the Impeller and Thermostat already and flushed the outdrive throroughly, but I've still got an intermittent random temperature fluctuation issue (acts similar to a slightly sticking thermostat). Thanks!
