Re: Should I add oil in gas as well as oil tank?
My engine is a 1990 200HP Johnson as well, and I was wondering if you can help me with one more question:
The RPM cage is not working at all. I haven't had a chance to check out the wiring just yet, but before I do can you recommend anything? Is there something specific I should be looking for? ...
The most common cause of the tach not working is a bad regulator / rectifier. You don't want to run with a bad reg / rec. If it's bad because it shorted out internally and you continue to run it, the wiring could catch on fire.
Is the motor still charging the battery? If you aren't sure, hook up a volt meter and run the motor at about 1500-1800 (you can do that on a hose in neutral). The voltage going to the motor should be over 12 volts. Almost 14.
Again, back to my experience with my 1990 200 (J200TXESM). As Dhadley said, it could be the rectifier/regulator (R/R). And, as he also says, another common symptom of a bad R/R is no charging.
However, my engine had a non functioning tach but was still charging 14+ as shown on the dashboard gauge as well as using a multimeter directly on the battery when the engine was at high idle.
Turns out the R/Rs on those engines can still charge when partially blown, and the only obvious symptom will be the non-functioning tach. You really don't know if it's a bad tach or bad R/R or bad wiring .
It is not a trivial question though because a new R/R can cost $250 retail, and the tach is probably at least $50, and testing the wiring - and maybe replacing it - can be a hassle.
So, test your charging. If it is charging, it could still be a bad rectifier or could be a bad tach. or bad wiring to the tach.
Before my amateur's experience and advice from my recent and only experience dealing with this, test your charging. If not - we can give you some more direction which way to go next. It involves things like substituting a known good tach, testing the wiring, bypassing the wiring from engine to tach, testing the R/R using the method in the FAQ. It's not hard, but you might not have to do all the various troubleshooting tests depending on the charging.
PS: you might want to start a new thread because the subject title now doesn't indicate your problem - you might get more and better advice.
