Completely disasembled carbs, soaked overnight rebuilt with new kits according to sticky in Q&A. Adjusted floats so they are ever so slightly higher than parallel to bowl at one end.
All new fuel lines.
Also installed new ignition coil.
Did Joe Reeves Link and Sync and found that timing was at 23deg. According to Joe's method, I adjusted to get 15deg (19-4).
Went through all of this because of no RPM's at WOT.
Put boat in water to test and it is bogging even worse than before when trying to get WOT.
Not overheating. Compression 130,125. Squeezing primer does nothing while running under load.
Did spark test on both plugs and jumped a 1/4" gap nicely.
At one time, motor rev'd high at WOT but only briefly and inconsistenly.
I did notice a slight click when new inlet needle came off of inlet seat. Put a drop of light weight oil on seat and click went away.
Almost ready to give up, unless someone has a great suggestion.
All new fuel lines.
