i inherited a boat with a (i think) 94 Magnum III outboard. when i first got it and cleaned out the gas tank, it ran very well with no problems. the alarm at the console would stay on constantly, but the oiler was working and the temperature sensors appeared to be working correctly. after a few times of taking it out, it started to miss enough so that it wouldn't plane out. i changed the spark plugs and cleaned the carbuerators, but it still wouldn't run properly. actually it started running only at a good idle. if i gave it some throttle, it would just choke out. the next time i took it out it wouldn't run well, but at full throttle would only be a good idle. coming back to the landing, the motor went dead and will not crank again. I've taken the carbs off again and cleaned them, used a different gas can to make sure the gas wasn't bad, but it still will not crank. it will turn over, but won't try to crank. i haven't checked the spark plugs again. about half way through this process, the tachometer started acting up. it would work some of the time and not work at others.
any idea what may have caused this?
is there a way to adjust or check the timing on this motor?
any help on this would be appreciated.
