Re: charging system
The 2000 8hp Johnson has five offerings - three consumer models (15, 20 & 25 inch shft lengths) and two commercial models (15 & 20 inch shaft lengths). The consumer models have rectifiers and battery leads in them, even though they are rope start, indicating that they have charging systems. The commercial models do not have rectifiers and battery cables.
Here are the models:
J8RSSB: Rope Start, Tiller, 15" Shaft
J8RLSSB: Rope Start, Tiller, 20" Shaft
J8RXSSB: Rope Start, Tiller, 25" Shaft
J8WRSSC: Commercial Rope Start, Tiller, 15" Shaft
J8WRLSSC: Commercial Rope Start, Tiller, 20" Shaft
PS: I just looked at the parts explosion for the consumer model motors again and noticed that the parts description for the stator, rectifier and battery cable includes the word "Sail." Whether that means that there is a "Sail" version of the motor in each of the shaft lengths, or if they are all considered to be "sail versions," I don't know. This is an important distinction because your motor may not have a charge system, if there are actually "sail" and "non-sail" versions. I would think, however, that even if your motor doesn't have a charge system, you could add one easily.
